Old 05-24-2014, 10:06 PM
I finally got all the hardware to assemble the bilge. you don't realize how much hardware it takes to install all this crap!
I got some of the stuff roughed in before I gelcoated so if I made a mistake it wouldn't be hard to fix. The first thing I do is install pumps, fuel filter, thru hulls. then its time to run the wires and hoses. you can see the thru hull transducer( compliments of trayder) also I used the Yamaha stainless fuel filter housing to keep it from getting crappy.
then came in some more hoses for the livewell and wash down its start to get busy
I also installed a brass sleeve back through the bilge drain. I set it in 5200 and sealed it up on the outside. so with it glassed and sealed with 5200 it should last a long time. plus it gives it a clean look.
gonna get the deck set back in this week
36' Yellowfin
1972 20' seacraft 140 suzuki
