Filled in some old thru hull holes, a strake, and cuts in the hull.
Beveled the glass back, laid some cloth on the outside and then thickened epoxy with cabosil and glass fibers and a bunch of 1708 layers on the inside. I'll go back over the outside spots when I do the exterior hull.
It's thick enough that I may put the seacock valve back at the same spot, esp. after the glass for the extension goes on.
