Originally Posted by Normagain
Is it a four stroke or two stroke? Stainless prop? . . .
Doozle, Norm is right . . . any advice you get will be meaningless if we don't even know what motor you have! 4-strokes typically have to rev higher than 2-strokes due to less mid-range torque on the 4S. When trying to select a prop, first make sure you've got the basic stuff right. (A tach of known accuracy, preferably a digital model tied into engine computer, and motor height correct (Top of AV plate above green water when on plane and trimmed out), and be sure to test with MAX load you intend to run, using water ballast if necessary.) And also check current prop to see what your min planing speed is with it. Some props will allow you to hang on plane at lower speeds than others, and that's just as important or maybe more so than WOT speed if you run offshore!
There is a lot more to to prop selection than just pitch and diameter! Two different props with the SAME pitch & diameter can behave much differently depending on blade shape, cup, rake and area, so if you want good advice, we also need to know what specific model prop and alloy type you're currently running. Stainless props typically have thinner blades so are easier to turn than an aluminum prop IF the blades are otherwise identical (but the blades are usually different too!) A prop for bass boats with lots of rake and bow lift for maximum speed will not stay on plane as well as a different (but same size) prop with larger blades and lots of stern lift! For example, if going from a BRP Raker (bass boat prop) to a BRP Rebel, one typically has to drop down about 2" in pitch even with the same diameter to get the same WOT rpm, because the Rebel blades are much larger and they slip less. If you're running a heavy motor (over about 300-350 lbs), you probably do NOT want a bow lifting prop! 4 blade props will provide more stern lift but may reduce top speed a bit due to more drag with the extra blade.
