  #30
Old 06-19-2014, 12:34 AM
Originally Posted by afishin82 View Post
Got a good bit of grinding done still a bit to go! Im gonna use polyester resin for the whole project so gotta make sure its scuffed pretty good! If I were to to use vynelester resin would the grinding still be neccessary?
Yes and no. Unless you need it flattened out, gritblast it instead. It is WAY faster. And it gets in corners. Don't skimp on washing up after and degreasing BEFORE you grind.
You need to clean and roughen for any adhesive bond.
Vinylester is technically epoxy. It just is cured like polyester. So if you get a good vinylester it is likely to stick better and be far tougher than polyester. You will know this for certain if you ever have to remove it.
