Originally Posted by berts80
Should the 2 layers be put down wet on wet?
Wet to wet is always best but there is a green windows that is still considered a primary bond. May be 8 hrs to 3 days depending on your resin. A secondary bond is not as strong and you will need to ruff up what your bonding to give it some tooth. Secondary will work if done right but wet to wet is the best for bond strength.
