Originally Posted by kmoose
Herds of Monkeys have been unleashed on my boat developing set up. But unless you are running the exact same set up, none of my specs will likely be close. My motor swings a 16x20 3 blade. That is very specific to the gear set and brand of motor I run and also drives the height I am able to run without turning blowout or cavitation and slippage in different sea conditions. The tipping point for having the motor mounted too high is not a blurry line that is hard to find and unless you are running your boat on a glass flat pond, don't be thinking you will be able to get away with a 20 inch motor..... because you won't without putting a snorkle on it.
Thanks Moose.. Exactly what i wanted to hear... ur boat tuned for your engine with height and prop and load... and No worries.. not getting a Snorkel for 23' think i found a 25" yamaha today...
Robert
