Old 08-12-2014, 07:33 PM
Progress is slow because I only have one day a week to work on it, but I got the whole interior sandblasted and cleaned. Then I installed 2 of the 4 stringer risers I made. The risers are 3 layers of 3/4" marine ply glued up with polyurethane glue. They are attached with a mix of resin, milled fibers and cabosil. Worked out great. The outer port side stringer is not perfectly plumb (installed that way) so I think ill cut my riser at a slight angle so they'll all be flat. Plus I want a slight crown to the deck for drainage.
