Thread
1974 20' sceptre transom replacement and i/o to outboard bracket conversion
68
09-01-2014, 08:47 PM
flyingfrizzle
Finally got some color on the hull over the labor day weekend. The bottom had 3 coats of two part poly urethane in light grey and the sides are painted Carolina blue. I got the inside primed with epoxy primer and faired out smooth after 3-4 rounds of epoxy filler and recoating. Once I get the last coat on the hull sides I will spray the inside white and redo the factory floor stripes with the grey same as the bottom but with awl grip nonskid aditive. Good to see it coming together and I can't wait to finish it so I can put more time in the 25' seafari. Note- the small trees behind the boat grew while the boat has blocked the mower if that tells you how long this has drawn out.
flyingfrizzle
View Public Profile
Send a private message to flyingfrizzle
Find all posts by flyingfrizzle
