If the delta for the motors & rigging is 150# and the weight of the bracket is 150# (a guess), you would have to offset 300# with flotation at rest to maintain the same waterline. That is about 5 ft3 in water displacement which should be pretty easy to get with a bracket if you plan it out. As far as running angle I think you would be ok there - lots of folks run brackets on the 23CC with great results.
