First thing Im gonna do is replace the bellows and other rubber stuff n the outdrive.
edit- upon inspection I believe we could go ahead and run her a few time before doing the bellows...there is only one small split an inch or so in the shaft bellows..I think I can put a little ultra blue on that sucker and go ridin. I thought there was a problem with the steering cable as well but it turned out to be loose from the linkage...back in place thread on another nut...done...done...new ignition switch...then pump the fuel tank.
thanks for the help and goodbye
