Originally Posted by Basketcase
I don't know if there is a crack. Its not obvious. In the front area it looks like erosion from repeated beaching but water was dripping slowly about 3 feet from the transom right at the keel. There is a piece of 2 inch really light cloth tape covering an area about 3 feet long. Your probably right in that I should add more. I do plan on adding 2 layers from the outside all the way front to back using epoxy. Would 2 layers inside and 2 outside be good? I've read some of the threads about cracks in this spot. I actually just almost bought a 2002 angler 20 footer with a crack in the keel for $1500 knowing I could fix it but I just don't have the space or time for it.
Take a load off your weary feet. Lay on your back and grind out the weepy spot on your keel
. Grind off bottom paint and gel coat to see if you have glass damage in that spot.
