Old 10-02-2014, 05:54 PM
hermco hermco is offline
Get a bracket designed for a 20" shaft motor. The bracket geometry/design determines the shaft length of the motor. Most are designed for 25" shaft length motors. You might be able to use some brackets designed for 25" shaft motors with a 20" shaft motor if you can mount the bracket low enough. Depends on the brackets design.
