Originally Posted by waterpressure
She needs to dry out for a month or so.
T
FYI - if there is wet wood, foam or balsa anywhere that is fully, mostly, or even partially enclosed with fiberglass (e.g. transom, stringers, deck) it isn't going to completely dry in a month, year, or decade without extreme measures. And then you still have the rot damage.
Plan on using a tyvek suit when you start grinding and cutting and remember that whatever you cut out comes out in 1/100th of the time it takes to put it back in.
Welcome and good luck
