Originally Posted by FishStretcher
Poplar plywood for the deck? It isn't quite clear from your post.
I have ranted about plywood in fiberglass boats before. I say things like it is heavy, wicks water, and is a termite hotel. I'll leave it at that.
Maybe you can get foam for a better deal than I can? I would suggest it. It is expensive, but you will buy a lot of resin and glass, too. Balsa seems to hold up much better and be lighter than ply, too. If I didn't do foam, I would do balsa before I did plywood due to the grain direction and density.
Good luck! It looks like you have a good start, some help and a great workspace.
FS, my apologies for the confusion. the poplar and 2x4's are
only to fasten to the topside of the deck temporarily to maintain a level deck while i do the resin and glass work below. there are high and low spots that need to be straightened before the Foam gets bonded to the underside of the deck not to mention the reinforcing of any structural issues when lifting the cap off.
