Old 10-27-2014, 07:43 PM
FAS FAS is offline
Originally Posted by CHANCE1234 View Post
If you haven't already glassed the 3" rigging tubes in yet, you may want to go with a larger diameter. I have 5" at least in my 20 with a single 115 and I wish I had gone bigger.
Chance, thanks for the response,I will add more foam to the aft end around the tubes on both sides it may help float the transom an extra 1/2 inch.the 3" tubes were a tight fit as it was, the way the 23 Sf stringers are made a 3" standard pvc pipe will not fit.I found OEM style sewer drain thin wall stuff.My boat originally only had one side tube and twin engines,talk tight!!, but now I have two full tubes,getting ready to Rig it...
