  #209
Old 11-16-2014, 10:59 PM
got some work done over the weekend
it was time to do the scuppers, decided to go out the side of the of the hull.
I used the long pilot bit, to scallop the floor for a drain. I used a 2.5 holesaw bit.
once I bottomed out I used the air saw to cut the piece out, I then proceededto core the balsa out from the inside. once that was out I cut and fit mat to the hole and wet out everything around it.
once that set I ground the goobers off and back filled the entire hole with dynaglass and smoothed it out. I let that set and drilled a 1 3/8" hole from the outside to center the dynaglass from the first pilot bit.
other than that I have just been tabbing and dry fitting everything I can.
36' Yellowfin
1972 20' seacraft 140 suzuki
