Old 11-19-2014, 09:16 AM
Originally Posted by ocuyler View Post
Thanks. I'm just getting ready to sand, prime, etc. the 19' Moesly Bowrider. That is all great advice. I have a good air 5" DA w/o vacuum and a good electric 5" DA with vacuum. Would you suggest investing in the Hutchins straight line sander at $300+ with all this work in front of me? Since I'm doing this indoors, dust is a real concern.
And at what point are you going to fill the holes in the transom?
Hutchins is one of the best. They are costly but you get what you pay for. There are many line sanders out there but most are just basic piston driven that only have a forward and backwards motion. Online you can get some low as $50 that are fairly good sanders but a line sander that is only directional one way (forward and back) will generate lots of scratches. I would use them for "ruff in" only! Usually they work best with 36 grit to 80 grit and will take down maternal fast and level it out well. Only problem is that they leave lots of scratches to fill or you can stop early and then finish down lower with a da and avoid filling them but you can take to much off to do this. Even with 320 grit you will get directional scratching with one. The one I have pictured in my earlier post is a Model 3800 which is a DA (Dual Action sander) It has the same size board 2 3/4"x16" as the straight line model 2000 but it has a action similar to the 5" or 6" da sanders most people use. It dose not leave the scratches behind like the piston driven model dose. You can use 180 -220 grit and get a good finish with it and still take down material fast. I get about the same finish (scratch wise) with a 320 hand block as I will with the 3800 hutchins with 220 grit in less than half the time. The narrow 2" wide block will get into tight curves while the 17" long board keeps everything flat and flowing together while working down a good section at one time. You can get similar results with hand blocks with lighter grit but you will work your self to death. They make a smaller version that is a 2 3/4" x 11" for tighter spots and they make a 2 3/4"x8" for even tighter spots. There is a 4 1/2" x 16" version and 4 1/2" x 9" for lager areas. They even have one that is a 8" x 18" for big flat areas like transoms and floors model 3805. The standard unit works well if just buying one but I would get 2 if possible- straight line model 2000 (hustler) for fast course grit and a Model 3800 for the fine light grit finishing. I have a $70 craftsman piston driven model that works fine but the 2000 hutchins is much faster and smother than the craftsman just like it. You can order any part to rebuild the hutchins sanders straight from them where the cheep ones you cant. A one time deal a cheep one will do just fine but you will have a hard time finding a DA action line sander for cheep. The straight piston course type is a dime a dozen.
For indoors all their models can have an optional vacuum attachment built into them,
What point do you fill holes in the transom? I fill any holes with fiberglass matt or 1708 if it is a bigger hole. Small tiny holes a syringe with thickened resin works well. I will do all the glass work First prior to priming and ruff it down with a 6" da or the course line sander then do any filling with fillers. Once I have everything close I will start priming, And at that point I will swith over to the 3800 da action line sander and work it with the fine grit. I use interlux watertite to do final filling if needed over the primer. It is a thin glaze putty that flows out well and can be used up to 1/4" thick they say but I try to keep it under a 1/16" if possible No more than a 1/8". At that point I will knock down the filler with a 6"round da for speed but use the line sander to blend large areas. The round 6" da works well for those small areas of spots of filler and random repair spots but if you try to do the whole boat with one it can cause the finish to have waves in it. The round sanders do well if held flat and worked right but you can get a flatter finish over a larger area with a long board or a block type sander.
One other product they just came out with, (I don't own stock in hutchin but do love their products) is the profinish line of round da sanders. They have a 3/32" stroke (model 500) for fine finish up to a 3/16 stroke sander (model 600) for fast sanding. This a cheaper line they came out with that is around $100 each on ebay new for da sanders vs the $350 for their 3500 original da's. I got one last year and love it. It is low profile and will not tilt over on you like the bigger more expensive 3500 model and they are composite not aluminum and are much more lighter. I know you can find da's from $20 to $500 and there are so many out there but I feel like their new proline series is the best bang for the buck you will find for a good quality sander at a fair price.
There are other brands like dynabrade that are just as good but I am a hutchins fan if you didn't know already, You get what you pay for and a few good sanders of the right type for the job goes a long way when redoing a boat....
I got 2 of mine used off ebay and one new for less than half price new and both were like new only used once and looked brand new when received. Shop around and you can find one for a good price. Jamestown dist. is fair on new ones too.
The standard piston driven single action:
The 3800 dual action:
The 3805: (this one is the larger 8"x 18")
This is the proline sanders that are reasonable priced:
