Old 11-24-2014, 11:55 PM
Originally Posted by keith View Post
. . . Do you think I should redo the penetrations that have been made, such as, the transducers, swim platform, trim tabs, etc? It seems like I should and at the same time I can check out for any rot. It's either that or apply adhesive around the penetrations to keep the moisture out.
Is there a tutorial or guideline for doing the drill, epoxy, drill method? How much larger than the bolt hole do you drill? What epoxy are you guys using? Do you paint it after? Do you seal around the outside of the bolt after it is in?
Thanks,
Very excited new Seacraft owner, Keith
Redoing all screw penetrations is cheap insurance if you plan to keep the boat for a long time, and might save or delay need to replace a core. Check out this West Systems Guide section 7.2.1!
