Old 12-04-2014, 08:00 PM
Originally Posted by 76pb View Post
Attachment 9081 put the rear storage back in use and built spash gaurd.
You might want to add some screws to that leaning post if you don't want it to come out in the ruff water on a bad day. One screw in each corner is not enough to hold it down. Just make sure you install it them, then take the screws back out them add some resin with thickener (a syringe works well for getting it in the hole) then reinstall them. This will help keep the core from rotting. Also if you want the screws to come back out ez add some wax to the before putting them back in.
Also welcome to CSC, I see this is your first post. Is this your first SeaCraft hull?
