Thread: T-Top Skins
Old 12-04-2014, 08:18 PM
Originally Posted by pair of jacks View Post
I'm considering converting to a thin, lightweight hardtop "skin"...
So, from your description, I'm seeing a thin laminate in lieu of canvas. I've never seen what you're describing, but the idea is intriguing.
You could take the canvas off your T-top and use it as a pattern to lay up a couple layers of 1808 with gelcoat on the top side and then drill holes in the same locations as the canvas, add grommets just like the canvas, and install it with nylon line, just like the canvas. It should be durable as long as there aren't any hard points that it would be stretched over, and it would be really simple to make. Is that what you're thinking?
Blue Heron Boat Works
