  #26
Old 12-12-2014, 07:55 AM
I knew center of the panel would get the best clean water, and have read that several times. I was curious with the two per side if you would go all the way to the outer two. That's the only place I can see that would work well. I don't know if they would fit on the center panels due to the outboard 6's would not clear each other. Just haven't seen a two panel seacraft with twins. All the others had tripples, that I've saw, minus the one inboard that was built out of the 10. Looking at other racing hulls with twin outboards they seem to be spaced far apart too.
