Originally Posted by CHANCE1234
I was thinking of drilling it out a little bigger than a fiberglass tube from McMaster Carr. Then insert the fiberglass tube and ensure it is flush with the bottom of the hull by placing a board and support under it to hold it in place then inject west system with a syringe around the entire tube from the inside to bond it in place. Remove bottom support, insert plug and go. Any issues with this plan
Chance, I had a similar problem with the OEM scupper tubes, where the wood block surrounding one of them was rotted pretty good. I carved out the rotted wood as best I could and then basically filled the entire hole with epoxy and redrilled it like you're planning. Instead of using straight epoxy which will just run all over the place, I'd thicken it to about the consistency of peanut butter to keep it from running and then use an empty caulk tube (many FG suppliers carry them) to force thick epoxy into the gap.
Here's the text of a post I made on the subject that might give you some more ideas:
06-04-2007, 12:13 AM
Epoxy fill of scupper holes using PVC core/pilot hole worked out well - mismatch between original hole & drilled hole at bottom was about 1/32", easily filled with 5200. Would have probably been better if I had used a flat wood drill bit with pilot feature instead of conventional bit which tended to walk.
Epoxy Fill: You will probably discover that the wood block is no longer sealed to the hull, so if you try filling it with plain epoxy as I did, it just runs out at the bottom. Next try with epoxy thickened to about apple sauce consistency worked well. I used MAS slow cure hardener & chilled it & resin in fridge first; otherwise it wants to kick off pretty fast once you pour it in caulk tube! Ended up using 3 caulk tubes, but wasted one due to sealing problem mentioned above.
Brass Tube Installation: (Ordered 1" ID x 6" long brass tubes from Boat Owners Warehouse, about $6 ea., got them overnight) The hole came out about 1/16" oversize due to drill walk, so filled it with 5200 as I slid tube in from top. Installed drain plug in top of tube first for leverage. Need to flare bottom of tube right away to keep 5200 from running out bottom because it's pretty slow to cure. Used a threaded rod, with nuts, washers and a 1/2" drive socket to get the flare started.
Results: After letting the 5200 cure for about 5 days, took the boat out for about 6 hrs, 4 of which was at anchor, bilge pump OFF for entire time. Pulled boat out, pulled bilge plug - it was dry, didn't leak a drop!
Here's a
slideshow with some pics I took of process. I like the idea of using a threaded thru hull for your application, so you'll have some mechanical compression keeping it together to fight vibration and relative motion between hull and inner liner/box that might loosen or crack the bond with a tube just stuck in with epoxy. In your case the trick will be to get a complete ring of thickened epoxy around the hole in the gap between box and hull. You don't have a 4-5" long hole to fill like I did, so maybe you could just use a putty knife or chisel blade in an exacto knife to fill the gap, or put some tape on inside of hole and drill some small holes around circumference of big hole and use caulk gun to inject thick epoxy thru them.
