Old 12-20-2014, 09:13 AM
I installed a garboard drain plug assembly thru the bottom of the keel versus out the transom. Therefore, the bilge can be drained while on a lift or a trailer from within the boat without climbing underneath. This also helps maintain the integrity of the transom from water intrusion
capt chuck were did you get your t handle? then was it just brazed on? I like that set up. my boat is lift kept also and I can not reach the drain plug to drain, this would solve that problem!
