Old 12-29-2014, 06:38 PM
bobbert bobbert is offline
Sounds like a shifter cable problem. Nine times out of ten the problem rests in the lower cable. The one that goes from the engine, thru the transom and down thru trasom ass'y tp the lower unit. If you have a "lazy shift" or a pop out gear it is definetly the problem.
Usual life is 4-6 years normal use. Good Luck.
