Old 01-19-2015, 01:18 PM
I might would try to cut out some oval or square holes in the sides then patch over them. if you cut the sides out you will loose the structure and could warp the hull. If you cut the holes you can remove it threw them by digging in out and the material left will keep the shape. Then once done glass over the holes and cut small ones at the top edges to refill the pourable foam threw.
Here is what I am talking about:
