Old 01-20-2015, 10:28 AM
shine shine is offline
Moderator
1708 or 1208 is your best bet for tabbing, the fiber orientation (45/45) allows more fibers to be "active" in the direction of th ejoint, plus it conforms better to curves.
To get a clean glass joint, you should work "wet on wet" with you fillet putty and the glass tabbing, so it all lays in there together.
here is my sole being tabbed to hull. I used epoxy so I did not need any matt, the tabbing is 2 layers of 12 oz biaxial.
here is the fillet (wood flour and silica mixed with epoxy)
tabbing of biax tape right over the "green" fillet. Epoxy used to wet out glass is the same used to mix up fillet putty - wet on wet, chemical (primary) bond
