Old 02-09-2015, 09:34 PM
chriselk chriselk is offline
Well I see I did not make pictures of the stringer repair where it went into the transom. Will get some more when I get a moment. Here are two showing Richard glassing in the new nidacore (yellow foam) linking the transom to the old stringer we cut out to remove the transom. He glued together 5 pieces and shaped it with a surefoam file.
He actually did this before he did the pour foam on the stringers. You can see where he brought the glass around in the corners of the transom. The corners (sides) near the transom are pretty shaky, so we beefed them up some with 17 oz glass and epoxy.
