Thread: Stretch 20
Old 02-22-2015, 02:02 PM
Originally Posted by slowJEEP View Post
I've been working on the layout of my 20sf now that I've got it stripped down bare. I've got a small case of 2 foot itis and am thinking about adding in 2-3 feet just forward of the transom . . . . Any thoughts?
IF your boat is a Moesly/Potter vintage hull, there are a couple of subtle features I noticed in the bottom panels when I painted the bottom on my boat that you might want to think about before you start splicing in an extension. I mentioned these features somewhere in a previous post a week or so ago, but I'll try to restate them here a little more clearly.
1. In the outer panel, if you sight aft along the chine from the front of the hull, it looks like there is a slight wedge built into about the aft 10' or so of the panel.
2. On the innermost panel, there appears to be a slight rocker in the last few feet forward of the transom.
I haven't been able to speak with Mr. Moesly to confirm the presence of these features, but they represent the type of sophistication which I believe are typical of his designs: The wedge in the outer panel would help the boat develop more stern lift to plane at low speeds, but since all planing hulls develop more lift as speed increases, I suspect that most of that outer panel is out of the waterby about 35 mph. The rocker in the innermost panel would then tend to raise the bow to get even more hull surface out of the water and reduce drag. This is a brilliant concept when you think about it . . . the wedge improves the ride at low speed when you want to slow down in rough conditions, but yet it's out of the way and doesn't hinder top speed when you want to run fast in flat water!
I believe the running angle data from the '69 Boating magazine article attached below supports this theory. Note that running angle tends to flatten out up to about 25 mph, but then starts to increase at a little over 35 mph! This test was done on an I/O powered boat with a CG located further forward than it is on an OB model, so this characteristic might be more pronounced on an OB powered boat.
IF your boat is a Tracker model, I suspect that none of this applies, because as Blue Heron noted in a previous post, there appears to be a slight hook built into his 20' Tracker model. Since they were produced later with more length and the 25" transom, they were obviously modified for heavier motors, and that probably makes them a better candidate for a bracket than the earlier models.
