hi guys,
thanks for all the interest and technical insight.
i looked into it as far as the dealer, i know his rep is impeccable. so i new the compression numbers where accurate. he says the yam 150 and many other 4 stroke compression numbers are that high.
they also do a leak down test which is a static test and the motor is tight (did not get the specific percentage of leakage). the only other point is that the compression test is done at cranking speed, so i am not sure if Adriatic (sp) heating is causing the higher compression at that rpm
thanks Lloyd that is what i was hoping for: 40 top, 5 mpg at cruise
thanks to all
mark
