Your existing console is smaller than the one that came in my 20MA. That sure looks like my 75 MA. Mine had a console with a head in it. At 38" wide it is not all that easy to move fore-aft, but not terrible. But finding room to mount a t-top to the deck becomes problematic.
Mine had a swing out door so you can get to the head. I cut the door off, put a tank inside the console and use a cooler as a seat forward. This year I will put a 2nd tank where the cooler is. I put flotation foam where the 50 gallon under deck tank was.
If that is a tank filler cap on the starboard side, the cap can get in the way of the filler. I have a 45 degree inclined one. If that is freshwater fill, then the dock hose shouldn't be an issue.
A haulout picture after a few hard weeks thrashing an estuary and buzzards bay. You can see how big that console is. You can't put rod holders on both sides, just one, so you can use the other for fore-aft travel.
