  #34
Old 03-24-2015, 02:46 PM
Chaser Chaser is offline
Well non-skid is done. Used Kiwi Grip again with great success. I blended the gray color darker than the standard KG gray, which is what is on the upper deck. Blending the KG was super easy, and it matches the upholstery color nicely. Now we are jonesing to re-paint the upper deck the same color! That will have to wait a bit though... At least I still have enough paint mixed up to do it.
Wiring is all done. Pedestals and seats are in (new seats are on order). Put oil in the Honda yesterday and started it up. Started right up and went right to idle after being stored for 2 months (and 4 months prior to that). I ran it for a few minutes to warm up, then checked the oil. Oil level was good, so I started it back up and let it run for a few more minutes. It was at that point that I realized I hadn't even put any fuel in the boat yet! It was running on the remains of what was in the fuel system during storage. I still can't believe it ran for that long with no fuel hooked up.
Today we are hoping to put the boat in the water and do a shake down run, check through all the systems. Hopefully finish up work early enough.
I still don't know why all the pic links are broken... They worked when I first put them up but now won't work at all. Anyway if you really want to see pics surf on over to the Google gallery here: https://drive.google.com/folderview?...Hc&usp=sharing
