Old 04-13-2015, 06:45 AM
Nice score! As a F100 owner, I have some advice to save yourself headaches later: Buy a 10 mm wrench. You will need to drain the carb bowls any time the motor sits for more than 2 weeks. Otherwise you will need to pull the carbs to change or clean the inline filters on the back side of the carbs.
I am curious what you have for a prop. I run a 4B Solas amita in 12-3/4 or 13" diameter by 15" pitch
Hello as the previous owner I can speak of the prop, i believe it is a 4 blade 14X17. The boat will turn 5900 rpms with two aboard, sad to see it go but lifes priorities dictate it. Best of luck to John.
