Finally in a spot to order my bracket and went out to measure the boat today. Anyone know if these sound correct? I'm sure Don will know but it's a Sunday and I would bet he is closed.
Transom is 14 degrees or 3.5".
(A)Widest width is: 92"
(B)Width at bottom of freeboard is: 87.5"
(C)Freeboard is: 29.5"
(D)Top of transom to bottom of keel is: 49.5"
(E)Top of drain to keel is: 2.75"
Also the transom has a slight curve to it, correct? I put a 72" straight edge across the back and the middle was "high" by maybe a 1/2" but looked like an even curve as you moved out.
