Old 05-09-2015, 11:30 AM
Ed Ed is offline
I am in the process of sanding the bottom and barrier coating spots under stands and blocks that previous yard never did. I also need to barrier coat the bracket and then paint the entire bottom.
Engines are disassembled. Sent out injectors to be tested and cleaned. All new filters, plugs, water pumps, seals, etc. going back in. I also need to pump out the fuel tanks as the fuel smells very old.
Old boot stripe is off. I have begun my two step buffing process (3M High gloss gelcoat compound followed by 3M imperial) - but it takes forever.
If time allows, I am going to sand, paint & prime the cowlings and pans. Then, I will run the boat for the entire season and see what I need to add to the list for next winter.
Oh yeah - I am in the process of making a cabin door too. The old one was made out of lauan or something similar and is falling apart.
Ed
