Originally Posted by cdlong
I found this article on sealing the gelcoat:
http://www.rvforum.net/SMF_forum/ind...?topic=52608.0
Red Max Pro 3 is not available any more from Lowes (certainly not anywhere in AZ) so we found that Home Depot have it listed as Zep Wet Look Floor Finish. This is exactly the same product, simply re-badged. See http://tinyurl.com/7ktf964
This process is for older RVs that have lost their shine and no longer respond to conventional wax.
I would be a little hesitant to use a floor finish intended for indoor use on a boat. You might want to check the label to see if it has any UV inhibitors in it. Or you could do what Bushwacker suggested. Poly Glo is a product formulated for use on gelcoat.
http://myboatstore.com/poliglow-refr...FQwbaQodJ7QAOQ
I've been using it for years.
Dave
