Looks like blockage between the holes in the lower unit and the bottom of the pump housing. Remove pump again and check. If not clear, you know cleanit up.
Had the same problem last fall caused by barnicles, and sea worms. After clean up get some outdrive anit fouling into the passage. Don't forget to check the holes in the lower.
Check to make sure nothing is reversed. Good Luck
