Old 06-04-2015, 06:59 AM
Originally Posted by cdlong View Post
Makes sense. I should have thought about Tstats because they are water cooled. Senior moment I guess. Now to figure out why the port engine has water flow immediately when started. Maybe Tstat is stuck open?
yes, It must be stuck open or there is not one in there. The mercury t-stats open up at 143 degrees and you will not have any flow out the tel-tel till it reaches that temp then it will open and you will get some flow. A lot of the time the water on the muffs coming from a water main is so cold that running a merc on the muffs the t-stats will never open. The best way to check them is to put them in a pot on the stove in water with a thermometer and heat them up and make sure they open and close. They only cost $10 each so I change mine bi yearly with the water pump impeller.
