Old 06-18-2015, 06:58 AM
It can be done, How I know? I done one my self. Here is the thread to a step by step way to make it happen. The twin outboard models will yeld a lot of floation if dropped down 2" from the hull bottom. Yours looks to be cut down in the rear for shorter motors so I don't think you will have enough mounting tab to get it low enough with out some additional work. I will tell you this tho, after doing one I will say you may be better off doing one from scratch. The dusky brackets are balsa cored but still have 3/8" of glass on each side of that. It will turn out to be a heavy piece. I built my swimplatform with foam and did it light as possible and it was still like 170-180# if I remember right.
http://www.classicseacraft.com/commu...ad.php?t=25504
