Old 09-07-2015, 08:16 PM
FAS FAS is offline
that will add tons of strength,also weight...try not to use too many 1708's.. great fiber and strength.but do not need too many layers....try this,.grind out the dry weaves,the skin cant be that thin,BUT,be carefull..put thickened resin(your choice)on the skin side and the core side, and put together with weight to force the excess out.clean up the edges and when dry put 1 layer 1708..use a hard roller to even it out.If you have access to a vacuum system, its a different process.It will all work out in the end !
