Old 09-28-2015, 07:15 AM
If you made it threw the long diarrhea of a post previous to this one you may of caught the part about using the correct tie wraps to secure the fuel, vent, drain and oil lines. The mercury oem ones are quite pricey so I found a set on McMaster Carr site and ordered them at a lot cheaper rate. If you guys need any while hooking up lines you should be able to get the PT# of the bag below. The other picture shows the difference in the two. The curved base of the correct ones will give you that 360 degree seal where the standard ones fall short. I know some of you may just use hose clams or worm clamps but if you would like to go back with the factory type ties here is a way to get them a much more reasonable price.
Name:  Tie wraps.jpg
Name:  Tie wrap pt#.jpg
