Old 10-16-2015, 10:13 PM
abl1111 abl1111 is offline
I've used awlgrip and awlcraft 2000. I did not notice a difference in applications. I recently sprayed Awlcraft 2000 on a sailboat and if you get a lesson about the right pressure to use, the right tip/nozzle and a how to apply with a paint gun, you can get great results. If you're good with using a spray paint can - you can use a paint gun. You just have to do it. I recommend practicing on a valueless pc of either fiberglass, or even a pc of glass to see how you do.
The real work is sanding and fairing - that is the art. It takes practice, a good eye and a feel. Using a sanding board really helped get a sailboat I re-did really nice. It really is 90% prep ! So, take your time and do it right. Then, buy the best paint you can afford and spray it !
