Old 11-25-2015, 12:19 PM
martin martin is offline
Question
Make a template of ho much coring you want. Lay it out on visquene or layup table and bevel your edges of corelay an over sized piece of glass say 3" all around. Then add your core bevel side up.. Then glass over this and encapsulate it.. And there you go... Once cured pull it off your visquene ..and rough up the visquene side and trim and fit into place.. Make some flimsy but strong wedges to fit and hold the part ul to the deck cap.. Now that you have it all ready . get some bonding epoxy like six10 and put a nice even layer.and glue it in place. Take your wedges or deadmen and use them to hold in place till cured.. And then just go ahead and reinstall your verticle pieces..this should take about a good weekend.. Good luck sir
Here's a sketch
