Without a picture I say you try to get them all out. Any where the heads break off drill them out or if they are very rusty use a punch and tap them through. Since you will want to re-seal the console at that point I would slide the console to the side where your wire chase is (Mine was starboard side) and lean it over. Then go ahead and pull all the the screws on the deck plat over your fuel tank. Clean everything up. Fill all holes then re drill and use the correct screws. Follow that up with sealant in the deck plate seams followed by the same when you put the console back. Should take you less that a day or two unless you run into trouble. But on the flip side it will give you time to look at your fuel tank and hoses and see if there will be trouble down the road.
