one of the smartest things you can do - to avoid a whole lot of problems :
invest in a few cans of that product I recommended to you - lear research corrosion block spray - or,get a gallon jug of CRC 656 - use those products and get in the habit of spraying down the motor - this will keep the moisture off and inhibit corrosion
do not use the cheap products - silicone,wd40,etc - they're useless,kinda like peeing on a forest fire....
