Old 01-18-2016, 05:47 PM
mikey813 mikey813 is offline
Default scupper headache input?
Thankyou, color is moon dust awlgrip. I only painted the windscreen frames with emron, replaced the crazed plexi on the side windows with tinted plexi. I built the battery box out of 1" starboard, just created a dam inside the step down to the cuddy, used 5200 and then a starboard top held with stainless screws. Makes getting to the helm a lot easier and puts some weight at the helm on the centerline. When I closed the transom (it was an out board) made a full width transom seat that opens to access the bilge. Ill post some more photos when the temp gets above freezing. Interluxe barrier coated the bottom after taking it right down to the gelcoat. One minor glitch, the boogers messed up the wedge just forward from the through hull scuppers and a helper who sanded the port side compromised the original shape. Makes the scupper look like a water fountain without the plug in while underway. Anybody out there have any thoughts about the original dimension of those wedges?? They are quite sensitive as I found out. Spring project
