Old 02-14-2016, 09:51 AM
FLexpat FLexpat is offline
Welcome.
Rule 1 - multiply your worst cast cost estimate by 2 or 3.
Rule 2 - double the time estimate (triple if you only double the cost estimate)
Rule 3 - What you can do with a grinder in 5 minutes takes at least 5 hours to replace (sometimes over 25 ).
I am not sure why you would lower your deck because it will no longer self bail. When I lived in Oregon it rained a bit - not self bailing is sometimes an issue in the rain. North Pacific is a bigger issue. Twins an extra foot off the back are probably ok with std deck height but sure are not raising the freeboard (&deck line) aft.
Originally Posted by DyeHard View Post
Replace the floor and lower it 4".
And 4" will mean that you get to cut the tops off of the stringers and replace your fuel tank - likely with a much smaller one. I think that is also lower than the chine line on the 23.
The rest of the ideas are interesting - some are a whole lot of work - take a very close look at how everything is built and figure out all the steps to re-do it before you start cutting.
Good Luck.
