Old 03-05-2016, 09:17 AM
martin martin is offline
This looks like my 20 before I redid the cap...I would not use silicon cause it is a bear to clean off to get a good chemical bond with the glass. I would pull cap off recorenwith composite and repair the broke or crcked glass. Grind or blast the underside. After you cut out the core ...you can clamp some Masonite cut down and waxed so it does not stick.. And use it as a semi mold to rebuild up the damaged lip on the cap....
My cap came apart cause of the slings in the boathouse... I now have a cradle...cradles are a must for these.hulls jmho..good luck
