Moesly SeaCrafts
I located the 4 stringers in my 67 Moesly Bowrider and cut 8 or 10 trapezoid inspection holes in the floor to see what had broken loose in the last 30 years. To my astonishment everything was still stuck together perfectly including the plywood subfloor except for one 12" X 12" spot. I poured some foam in the outer stringer spaces, glued the floor inspection ports back down, and laid a couple of thin matts down on the floor before gelcoating the no-skid in place. That was back in '99. It's still as solid as a bowling alley.
Press on Brother, you're better off with a 69 Moesly that a 2008 Proline, Bayliner, Wellcraft, Aquasport,_________fill in the blanks.
