Old 04-27-2016, 04:20 PM
It's easy. take off the transom skin, remove the mush and prep the inside and outer surfaces properly and you WILL have a good bond. One of the secrets to the Arjay is how they are able to keep the cure temperature at a steady level, I think 180 degrees, not positive of the number. If you poured that much mixed regular fiberglass resin in a closed area the heat would be crazy. When I did my 23 I was amazed how thin the inner skin was, basically a moisture barrier, the transom skin was a different story.
