Old 05-02-2016, 06:09 PM
72potter20 72potter20 is offline
Default Trim tab placement
I've been meaning to put tabs on my boat for some time now. A local marine supply had a great deal on a set of Bennett m80's so I picked up a set.
After doing some researching it appears that the preferred mounting spot is on the outer most step. My transom will not allow this unless I do some major relocating of various things.
They will however fit perfectly on the middle step. Has anyone mounted tabs here? Should I go ahead and put them there or go ahead with relocations? Relocating would mean many new holes drilled in the transom
